AnKaranirThanagor
LOG <<<
Example video 00:25
Hi everyone,
I'm facing an issue that I've been unable to resolve for a long time. During both the OBS preview and the final recording, I experience unexplained periodic FPS drops/micro-stutters that last for about a minute and then disappear. On a 1-hour video, this behavior occurs roughly 5 times.
I have tried literally everything: tweaking BIOS settings, testing various driver versions, and modifying various Windows settings. I have thoroughly searched the forum history dating back to 2019, which is when similar issues first started appearing in threads.
Crucially, this problem occurs identically across all recording software (not just OBS). It is not an OBS-specific bug, but I'm posting here because this community has the best expertise in capture pipelines. In my opinion, this is either an Nvidia driver flaw or a deeper DXGI issue. It seems Nvidia managed to mitigate this on the 30 and 40-series GPUs, but the new 50-series is suffering from it again.
Please do not suggest basic troubleshooting like disabling HAGS or running as admin; all of that was tried a long time ago. I have completely swapped out my hardware over time: the monitor, M.2 drives, GPU, and motherboard have all been replaced. At this point, the only remaining original components are the CPU and RAM. I have cycled through every possible combination of OBS, Windows, and Nvidia Control Panel settings, and almost nothing has any impact on the issue, except maybe V-Sync.
My System Specs:
Any advanced technical insights would be highly appreciated.
Example video 00:25
Hi everyone,
My System Specs:
- Setup: Dual-monitor setup, G-Sync is completely disabled.
- Monitors: Main monitor is 240Hz, secondary is 120Hz.
- Motherboard: Previously MSI B760 Tomahawk Plus WIFI, currently Gigabyte AORUS Z790M Elite.
- CPU: Intel Core i5-13500
- GPU: Previously RTX 5060 Ti, currently RTX 5070 Ti.
- RAM: 32 GB DDR5 @ 6000MHz.
- Storage: Kingston SKC3000 1TB (System drive) + an identical Kingston SKC3000 1TB (Dedicated drive for recordings).
- OBS Settings: Canvas/Output set to 60 FPS, AV1 encoder on Medium presets.
