using capturecard for obs, sometimes preview fps drops.
  • Thread starter Thread starter Deleted member 232123
  • Start date Start date
D
using capture card to record and sometimes ive seen frame drops on preview (using hd 60x to capture), trying to use this to stream to friends on discord and sometimes ive noticed that the fps doesnt feel like 60
Does this happen when you're not recording/streaming? If not, then your encoder settings could be using additional GPU which may cause rendering lag. Two Passes Multipass Mode, Look-ahead, Psycho Visual Tuning and Presets P6 and P7 (AFAIK) all use additional GPU when using NVENC. If you have Browser sources/docks and Browser Source Hardware Acceleration enabled, that will also use additional GPU. Close any other programs that use GPU.
If still having issues, then
Not when streaming/streaming because I'm just using this to stream to discord using the fullscreen projector, would two pass cause that?
Would my encoder settings cause lag on the projector preview?
1. Run OBS as Administrator. Right click on the OBS shortcut, properties, advanced, check box, ok, apply, ok.
2. Disable Psycho Visual Tuning, keep Multipass Mode at Single Pass, and change your Preset to P5. If still having issues, try P4.
If still having issues, please post a clean log. Your log contains no recording or streaming session. Results of this log analysis are limited. Please post a link to a clean log file.
1) Restart OBS.
2) Start your stream/recording for at least 30 seconds. Make sure you replicate any issues as best you can, which means having any games/apps open and captured, etc.
3) Stop your stream/recording.
4) Select Help > Log Files > Upload Current Log File. Send that link here.
I got a solution fot my FPS / Framerate preview drop. On nvidia control panel / Manage 3D Settings / Program Configuration - Select OBS Studio and search for Power Performance Mode and choose Preference for maximum Performance and apply. Restart OBS and it worked for me.
People with dual PC go to your STREAMING PC nvidia settings and select "Use my preference emphasising" and choose "perfomance"
i dont know why this helped with Elgato HD 60+ S
i dont get those annoying stutter anymore
Made 1min test with wow
Thanks, it works fine for me.
Now I can play the game smoothly while watching the OBS preview.
My streaming PC is sufficiently spec'd, and my CPU and GPU usage never goes over 50%, but I was always getting the preview lag and poor recording quality, so I was giving up on this issue.
OBS logs don't spot these types of preview errors.
Anyone using a capture card should try this.
However, the "Performance" preset forces you to turn off VSync depending on the program you are using, so you may need to keep a close eye on your GPU usage in Task Manager and set a frame cap if it's too high.
I made an account just to write to you, I have a near stream ccd10 4k60 and could not for the damn life of me figure out what was causing these frame drop issues, I tried literally everything in terms of settings and hardware and console and nothing happened… ON A WHIM I did this step and it actually fixed lol…. Here confirming that it works on other cards besides elgato and to thank you again!
is there a way to turn this setting on for ONLY Obs?
