cl4pm0w
Good evening everyone. I did quite a lot of tests aaand it still stutters.
Here are my spec details so you can compare them for your convenience.
Streaming Rig (no overclock or antyhing, just the XMP profile enabled in BIOS):
Asus ROG STRIX X570-F Gaming
AMD Ryzen 9 3900X
32GB (2x16GB) @ 3200MHz (Corsair)
EVGA 1080Ti 11GBytes
Samsung SSD 970 Evo 1TB (used for testing the recordings, wanted to avoid any bottleneck)
Video Tab: Base and Output Resolution: 1920x1080p
Output Tab - Recording: Rescale Output to 1536x864
Gaming Rig (same as above, no overclocking, XMP profile and that's it)
MSI Z370 SLI Plus (MS-7B46)
Intel Core i7 8700k
32GB (4x8GB) @3200MHz (Corsair)
Asus ROG Strix RTX2080Ti 11GB
Video Tab: ( afaik nothing else needs to be set for NDI, correct? )
Base Resolution: 2560x1440p
Test cases*:
* CPU Usage for the streaming RIG is at max 50% - NO dropped frames, NO encoding lag
NO dropped frames, NO encoding lag for the gaming rig as well (probably 2 dropped frames due to encoding whilst playing Doom/Anno, but GPU usage was really high and this was expected imho)
Final Test NVENC with NO impact even though GPU usage is around 60-99% at the gaming rig.
7. Anno1800 - DX11 - CQP - 16 - key frames 2 - quality - profile high - b-frames 2 - no look ahead - psycho enabled - capped 100fps
8. Doom Eternal - DX12 - CQP - 16 - key frames 2 - quality - profile high - b-frames 2 - no look ahead - psycho enabled - capped 100fps
I can upload all Testvideos to youtube if needed.
Additionally I will attach all logfiles for those tests from BOTH machines.
Haven't taken any look into them yet, was busy collecting all the data ...doing some WoW stuff with friends in between haha.
Will do that tomorrow!
Still it baffles me that the x264 isn't really working anymore...It's not a real enthusiastic test, but I wanted to test mutliple games with nearly the same settings to see if anything changes on the streaming rig, maybe the gaming rig could've been the issue, which it clearly isn't.
Would be interesting when/if this get's fixed sooner or later.
In the meanwhile, my solution is to use NVENC for now, kinda curious though if streaming with NVENC to Twitch will work, but I'm pretty sure it will.
Uploaded files do have SR (streaming rig) and GR (gaming rig) in their name to distinguish them.
Have a good night and regards,
cl4p
AMD Ryzen 9 3900X
Intel Core i7 8700k
Test cases*:
- WoW - DirectX11 - CBR - 6000kbps - CPU slow (or medium) - profile high - key frames 2
- WoW - DirectX12 - CBR - 6000kbps - CPU slow (or medium) - profile high - key frames 2
- Doom Eternal - DX12 - CBR - 6000kbps - CPU slow (or medium) - profile high - key frames 2 - uncapped
- Doom Eternal - DX12 - CBR - 6000kbps - CPU slow (or medium) - profile high - key frames 2 - capped 100fps (better, still stutters though)
- Stardew Valley - DX10 - CBR - 6000kbps - CPU slow (or medium) - profile high - key frames 2 - uncapped
- Anno1800 - DX11 - CBR - 6000kbps - CPU slow (or medium) - profile high - key frames 2 - capped 100fps
cl4p
