Source Record
Source Record 0.4.8
I like this a lot. However I'm having an issue with the different audio section and need some clarification on how it works. Right now, I tried to just record from a live source without selecting any audio track. It's not working. The source is picking up audio as I see from the audio meters but for some reason it isn't recording it. The source is in the same scene being recorded in source audio.
Hi, sorry to asks again, but with recent updates including Audio options, is it possible to DISABLE the recording of the Audio when using Source record? I record two cameras at the same time, one using Source Record for just a headshot and no need for audio. I select no audio but the resulting MKV file still provides an empty audio track. Hope that make sense. Thanks.
Hi, trying to download for Mac, packages won't open, reading as malware.
@k0ntroversial in vesion 0.4.3 and up you can select to record all audio tracks.
Any idea if Source Record will get the Checkmark boxes for audio like OBS currently has? When I record all audio, it records Gameplay audio on Audio Track 1, ALL audio (mic, GAME, chat) on Audio Track 2, and my Mic on Audio Track 3.
I need the following Audio tracks:
1) Gameplay only
2) My mic
3) Discord and Game Chat
i have a bug - when i add this to filter on camera source --- the camera will always run and be open and take resources - even when i change the scene - without using this filter - it works as expected
Can you elaborate on what you think is the bug?
I have recordings going on multiple cameras and need them going even if I change the scene, so they will be recording and utilizing resources as expected. This is the intended behavior as I understand it and how I use it. Are you asking for a feature that would stop recording for an object not used in the active scene?
In my case, I would like to have a feature where I can specify recording groups. When streaming I need all objects recording at all times. But there are less common occasions, where I just need 1 of the filters to record. Currently I have to record all, and then go delete the other 6 unneeded recordings to just keep the 7th.
Hey there, first of all, thank you so much for this tool, as it's helped me quite a lot in the past, but I've recently had to do a fresh install and for some reason I'm not being able to Replay buffer two different sources (webcam + gameplay) :(
Any idea of what might be causing an issue here? The gameplay records fine, but the webcam for some reason has not been wanting to cooperate :(
I've got them both going to separate folders, different names, same settings, I've tried with different encoders as well with no luck, as I can't recall my settings that I had put 1+ years ago.
Any help is welcome!
Wishing you a great day,
OCRRAM :)
Have a question. is it possible to have the streaming section use the same settings as your main encoder in order to save resources. Instead of using double resources to stream in different locations?
Hello! Variable recording time under 20 seconds.
In my project, sports capturing, I would like to save the last 7 seconds for highlights.
When I use the standard obs replay buffer, it always saves the duration I set it too (7 seconds).
When I use the Source Record plugin, it saves in various times from 20 seconds to 1, no matter value I set in the Source Plugin filter.
I saved a highlight for every second, using the Source Record plugin, and it recorded videos from 20 ,19, 18, ...., 3, 2, 1, seconds and then it started saving again from 20 seconds to 1!
Standard obs replay buffer does not behave like this, it starts from 1 second until it is full (7 seconds). Then, it constantly saves a 7 seconds highlight video.
I believe Source Record plugin, should work the same way.
Thank you for your support.
I hate that the "Masterfile" of the recording is 100's of GB when the indy sources are under 10GB and it maxes out my storage an then stops recording and corrupts the files
love using this. only wish it could record multiple audio's tracks like normal obs does. would make it grate for streamers that want to record on one secen and stream on another. + audio splitting it good for editing out copyright music in games without muting the whole video. besides that im still going to use it. thank you for the grate work that's making this.
You can. Just choose "Audio Track" = "All" in the Settings for Source Record. Let "Source" empty.
You will get all 6 tracks in the record.
@Exeldro
I just have a quick question and a small request.
The question: Which rescaling method are you using while rescaling within source record? Lanczos? Or which value from OBS itself are you looking at?
The request: I'm trying to record parts of my stream with source record. Works very fine. Currently I'm using the Record Pause option of OBS which is very nice in order to have a continuous file. Source record does recocognize pausing very well.
But....the "Default OBS record" does cost performance on the cuda cores and it's useless for me anyway. I just need the pause itself, not a record of OBS with things I don't need because the streaming view is recorded.
Do you see any possibility of manually controlling source record so that it pauses?
@Valcry in the current version we don't set a scale type, here a version that lets you set the scale type:
You can download the test build when logged in on GitHub from the bottom of this page:
Manual pausing of recordings is at the moment not planned to be added.
Wow, thank you very much for this really quick reply. And for adding scale type with this ad-hoc checkin. Great.
I just tried to redownloaded source record because I noticed the settings where gone to adjust things and now its not in my effect filters any fix?
Hi I noticed that the source record recording output usually is cut short? Just wondering if you are aware of this issue and know how to fix it. I'm using the "Always" setting so that I just have to toggle the filter on/off to record. I save the recording as hybrid_mp4, and pretty much everything else is left untouched. I'm wondering what is causing it to do that.
