Reinstalled OBS and now drops frames in my recordings.
IDK, my BIOS is pretty much default. No OC, nothing except XMP using G Skill's OC not Asus. About the only other change I made was the GPU settings.
@rockbottom turns out the rabbit hole goes deeper. My PC doesn't show a boot splash so I can't access BIOS. I feel like I am going insane. Is BIOS the only way you know of getting OBS to not priorities my GPUi instead of my 2070?
Although my gut is saying something bad happened internally. While most things are fine, Spotify's been unable to play any music (just says Spotify can't play this right now) and my OBS disintegrated. If I knew moving my PC from the left side of my desk to the right would cause such damage I would have left it there.
Where are the monitors physically connected? They both should be connected to the 2070 & nothing should be connected to the HDMI out on your mobo, leave that empty.
You may need to get somebody that knows their way around the inside of a PC case. It could be something stupid, like your GPU came unseated or a wire got knocked loose.
Restarted OBS and got this in log
14:36:21.442: Initializing D3D11...
14:36:21.442: Available Video Adapters:
14:36:21.445: Adapter 0: NVIDIA GeForce RTX 2070 SUPER
14:36:21.445: Dedicated VRAM: 8377073664 (7.8 GiB)
14:36:21.445: Shared VRAM: 34276433920 (31.9 GiB)
14:36:21.445: PCI ID: 10de:1e84
14:36:21.445: HAGS Status: Disabled (Default: No, Driver status: Supported)
14:36:21.445: Driver Version: 32.0.16.1062
14:36:21.446: output 0:
14:36:21.446: name=VG279QM
14:36:21.446: pos={0, 0}
14:36:21.446: size={1920, 1080}
14:36:21.446: attached=true
14:36:21.446: refresh=60
14:36:21.446: bits_per_color=8
14:36:21.446: space=RGB_FULL_G22_NONE_P709
14:36:21.446: primaries=[r=(0.646484, 0.340820), g=(0.306641, 0.639648), b=(0.150391, 0.047852), wp=(0.313477, 0.329102)]
14:36:21.446: relative_gamut_area=[709=1.105803, P3=0.815166, 2020=0.584827]
14:36:21.446: sdr_white_nits=80
14:36:21.446: nit_range=[min=0.000000, max=400.000000, max_full_frame=400.000000]
14:36:21.446: dpi=96 (100%)
14:36:21.446: id=\\?\DISPLAY#AUS278F#4&3623efdd&1&UID224795#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
14:36:21.446: alt_id=\\.\DISPLAY6
14:36:21.447: output 1:
14:36:21.447: name=BenQ GL2460
14:36:21.447: pos={-1920, 0}
14:36:21.447: size={1920, 1080}
14:36:21.447: attached=true
14:36:21.447: refresh=60
14:36:21.447: bits_per_color=8
14:36:21.447: space=RGB_FULL_G22_NONE_P709
14:36:21.447: primaries=[r=(0.641602, 0.333984), g=(0.333984, 0.624023), b=(0.152344, 0.049805), wp=(0.313477, 0.329102)]
14:36:21.447: relative_gamut_area=[709=1.023304, P3=0.754350, 2020=0.541196]
14:36:21.447: sdr_white_nits=80
14:36:21.447: nit_range=[min=0.500000, max=270.000000, max_full_frame=270.000000]
14:36:21.447: dpi=96 (100%)
14:36:21.447: id=\\?\DISPLAY#BNQ78CE#4&3623efdd&1&UID198195#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
14:36:21.447: alt_id=\\.\DISPLAY5
14:36:21.447: Adapter 1: Intel(R) UHD Graphics 630
14:36:21.447: Dedicated VRAM: 134217728 (0.1 GiB)
14:36:21.447: Shared VRAM: 34276433920 (31.9 GiB)
14:36:21.447: PCI ID: 8086:3e98
14:36:21.447: HAGS Status: Disabled (Default: No, Driver status: Unsupported)
14:36:21.447: Driver Version: 31.0.101.2135
14:36:21.447: Loading up D3D11 on adapter NVIDIA GeForce RTX 2070 SUPER (0)
14:36:21.640: D3D11 loaded successfully, feature level used: b000
14:36:21.640: DXGI increase maximum frame latency success
14:36:21.640: D3D11 GPU priority setup success
has it finally booted with the right GPU?
@rockbottom omfg... my monitors were connected to the mobo. Ig this is what you get for moving a PC late at night. Display Capture now isn't black for my preview, and OBS loaded up for a second and third time with 2070 GPU. Seems nothing beats plain old human stupidity. I'll test some recordings and see whether they lack or not. I'll report back whether it's good or bad news. Thanks so much for the help (again)
