Recorded Gameplay Flickers (not in game, just the recording)
AlphaWu1f
Recently setup a new computer to play/record with through OBS.
i5-10400
RTX 2060 Super
Running OBS as Admin
When I try recording, the game plays super smooth with no issues, but when I watch the recording it has a flicker across the whole screen, most noticeable the more I'm moving.
I'm new to the whole recording aspect and not sure what to adjust/what could be causing this issue. I tried searching the forums but couldn't find a solution.
Log file and OBS settings are attached.
Video example below, low quality clip but it shows the flicker.
Thank you for your help!
  • 2020-08-27 11-08-15.txt
same problem here. latest nvidia driver installed. The recording is flickering like hell. Have you found any solution?
Nope unfortunately no fix yet; I’ve tried Googling and tinkering with settings but nothing seems to fix it. There’s basically zero dropped frames so it’s not lacking processor power, I’m thinking it’s something to do with encoding settings?
i5-10400
RTX 2060 Super
I'm currently making a video explaining how I was able to fix this problem after a couple of moths of dealing with this in OBS Studio and Streamlabs OBS for youtube so I can share it here. This problem has been very annoying to deal with as im sure it is for yourself.
Dude yes! I’ve tinkered with every setting possible one at a time to no avail, I so look forward to your video! Hopefully it fixes the issue for me as well
my problem is gone as soon as i turn off nvidia graphic filters. Is that any help for you?
Hmmm I’ll check if mine are on still! I just recorded the other night and it worked fine and I could t figure out why, I’ll see if I turned the filters off at one point! Thanks for the heads up
Ah mine are off now! Must have reset after an update; I can't believe I didn't think of checking that before. Thank you! That seems to be the solution for me!
i5-10400
RTX 2060 Super
I'm not an expert on this so don't have a full explanation for why the timing and ratios for monitor refresh rate and video output frame rate matter but made this short video showing my settings and what fixed this for me.
Relevant Specs
  • I5-9600k (4.7GHz)
  • GTX 1660 Super (6 GB) OC to 1935MHz
  • 16GB RAM (3200MHz)
  • EVGA 650W (60+ Gold)
  • Samsung 1TB SSD
  • Seagate 10TB HDD
(link to video)
Relevant Specs
  • I5-9600k (4.7GHz)
  • Samsung 1TB SSD
  • Seagate 10TB HDD
(link to video)
Thanks for the information! For me it was fixed with the suggestion above turning off Nvidia filters.
i5-10400
RTX 2060 Super
I was receiving the same issue ,below is a video on how i resolved it
Thank you! The only issue now is the yellow frame around the game from Windows
This seems to work great! Thank you for the help. It is annoying having the yellow frame around the screen because of that (damn Windows) but very worth it to record with the filters on.
i5-10400
RTX 2060 Super
Have we found a solution for this yet? Running into it now and its super frustrating
I turned off the Nvidia filters and haven’t had an issue, like he mentioned above.
But also I tired the window capture and that worked WITH the filters, but I switched back to game capture... at this moment I can’t remember why exactly but it was important for some reason and not worth bothering about the filters to me
Fix: After disabling Desktop recording in Shadowplay, my buffer replay recording have no more flickering issue.
Shoutout to reddit post by Tostecles in this thread.
I am having similar issue. But in my case I have different setup. I am using OBS and NVIDIA Shadowplay. OBS to live stream/recording sometimes. And Shadowplay mainly for buffer reply. I know OBS does as well, but so far haven't explore.
This issue happened with the latest NVIDIA drivers 527.56. Haven't noticed it before. When I am using only Shadowplay and enable Desktop recording, I don't have flickering issue. It only happening when OBS running with Window Capturing (in my case to capture game) and at the same time Shadowplay buffer used to record.
Hello not sure if this is the same issue like i had on some games when you look at your display monitor in obs and game would be like having a seizure shaking like crazy when walking around or looking
window mode in obs fixed that for me smooth as clear
