Preview/Program Issue
At least the log looks better with all of those errors out of the way. Not wasting the cycles anymore either. Making progress
19:33:06.294: [Media Source 'Wait BG']: settings:
19:33:06.294: input: C:/Program Files/obs-studio/OSD/Mysterious technology space particle background.mkv
19:33:06.294: input_format: (null)
19:33:06.294: speed: 100
Not that I could notice but I didn’t have as many sources as I usually have. I usually have two webcams and two instances of iVCam plus a capture card going.
Exactly, less load with only (1) source/possible bug(s) out of the way & the stuttering has improved to the point it's not noticeable.
The old collection has too many Media Sources using acceleration, no changes were made. The decoder in the Nvidia GPU's is only good for 2 maybe 3, after that it's downhill. The collection may need further troubleshooting if that doesn't help but start there. I run a very simple set-up for a reason, nothing is free.
Disable Game DVR, that may save some resources. Update the damn plugins.
I have a problem mixing Global & Source audio & never use them concurrently. I'll leave it at that.
Is there an easy way to update plug ins? The update section is greyed out on my plugin manager.
Also how can I disable game dvr? I was unaware I had it on. I’m doing absolutely no gaming of any kind on this right so I tried to remove most of those functions.
I went through and unchecked hardware acceleration on the two sources I had it on. Is there another way? Is hardware decoding the same because I unchecked it as well. Two of my replies never posted but I also turned off low latency audio.
I use (1) plugin. When updating, I remove/re-install it with OBS closed. I re-start my PC whenever I install new apps. Never had any issues.
Game DVR, Windows Gaming
No, have to open up the properties for each. There was (4) Media Sources using it. As I said before, tons of RAM on that system so disable it for all of them.
Yeah, I saw that it was back to dynamic in the last log, all good.
I turned off Game DVR. Gonna try another log file and then update my plug ins and hunt down the media sources using hardware acceleration.
The first log is with accelration on and the second has it turned off.
No lag in either log.
Browser acceleration should be enabled. I was asking for you to disable acceleration on the Media Sources to see if the stuttering ceases. If it doesn't the collection will need further troubleshooting that can be time consuming. Personally, I just re-build a new collection if/when things go sideways.
So should i re-enable that? I went through my sources, I did not see anymore with hardware accelaration or decoding on
