I am using the **ezcap314 Dual CAM Link** with two cameras connected at the same time.
When both cameras are active, the video intermittently freezes and cuts in and out. OBS also reports decoding errors such as **"No JPEG data found in image"** and **"Error decoding video."**
Could you please tell me what the recommended maximum resolution and FPS settings are when using both HDMI inputs simultaneously?
For example:
* Should both channels be set to **720p30** (total 60 FPS)?
* Or **720p25** (total 50 FPS)?
* What is the maximum total FPS supported when both channels are being used together?
I would appreciate your recommended settings for stable operation with two cameras. I have already sent you my OBS log file.
Thank you.
we.tl
For example:
Thank you.
2026-06-28 09-00-02.txt
1 file sent via WeTransfer, the simplest way to send your files around the world
