OBS Studio 32.2 Beta
Fenrir
Forum Admin
Disclaimer: This is a test build, not a full release. Please ensure you make a backup of your scene collection and profile. This build may contain bugs or broken functionality. For production usage, we still recommend using the latest stable build of OBS. If you are willing to test this build, let us know if you run into any issues.
OBS Studio 32.2 Beta is now available for testing. Give it a try and send us your feedback!
This minor release adds in the new Add Source dialog, which we are excited for as it should make the workflow of adding a source much more intuitive and consistent for everyone. We're still very interested in your feedback on this one, and have a dedicated channel in our Discord to provide any comments you may have, even if it's just to say you love it!
Additionally, we've added .webp support for Image Slide Show source, updated the Missing Files dialog to support filters, implemented some minor performance enhancements for OpenGL, and added several QoL/UI fixes and tweaks.
See the full list of changes and download links for OBS Studio 32.2 Beta 2 here:
To enable the beta version, either download from the GitHub link below, or on Windows/macOS go to Settings -> General and change the Update Channel to Betas / Release Candidates
For other ways to install the beta:
To access the beta via Steam, right-click the OBS Studio entry in Steam or click the cog icon on the game page, select "Properties...", then navigate to "Betas" and select the "beta" option in the dropdown:
1659496483190-png.85265
Ubuntu users: You can try the unstable branch with the following commands:
Bash:
sudo add-apt-repository ppa:obsproject/obs-studio-unstable
sudo apt update
sudo apt install obs-studio
And if you want to remove it:
Bash:
sudo add-apt-repository --remove ppa:obsproject/obs-studio-unstable
sudo apt update
sudo apt remove obs-studio
To use the beta version from Flathub, please use the following commands:
Bash:
$ flatpak remote-add --if-not-exists flathub-beta https://flathub.org/beta-repo/flathub-beta.flatpakrepo
$ flatpak install flathub-beta com.obsproject.Studio
Please give the build a try and let us know here or in the #beta-testing channel on Discord if you have any issues or feedback. Thanks for your help!
All my Nvidia broadcast SDK effects have disappeared from OBS in this update I can't see any of the audio effects or camera effects such as remove background, add blur, Nvidia nose suppression etc.
You probably need to update de SDK, like in any other OBS update (not minor)
From the log:
13:32:40.175: [NVIDIA Audio Effects:] version: 1.6.1.2
13:32:40.256: [NVIDIA Audio Effects:] NVIDIA denoiser disabled, redistributable not found or could not be loaded.
13:32:40.256: [NVIDIA VIDEO FX]: NVIDIA VIDEO FX version: 0.7.6.0
13:32:40.280: [NVIDIA VIDEO FX]: enabled, redistributable found
Which seems to indicate that the audio SDK is either not properly installed, or missing entirely. Make sure you grab both the Audio and Video SDKs from that link you posted, with the correct GPU series (50 series in your case).
Make sure OBS is closed while doing this, and to be safe, I'd reboot after installing.
From the log:
The video is working properly its only the audio that is failing
Does rolling back to OBS Studio 32.1.2 allow the filters to work properly? If so, can you post a log from 32.1.2 as well?
I cant post any log from that version but when I rolled back to redownload my OBS it was working properly its only this specific version of OBS that breaks the Nvidia audio filers
I don't know if this is a OBS thing or an extensions thing, but it seems this new way of loading Dlls has also broken my streamup plugin the (advanced scene switcher)
Can you please provide a new log file from where this is failing to load? Also the Advanced Scene Switcher is not a streamUP plugin, I'm unsure which you are referring to as not working here.
Ok then in that case its just general bits of it are failing
