OBS Crashes anytime I close it.
Joshua6547
Hello, kind people!
I have been struggling with my OBS crashing anytime I close it. It's been doing this for a while now and I've finally gotten to the point where I'm annoyed by it enough to reach out and ask for help! I will post the most recent log file here.
I didn't record anything during this session but it crashed upon closing, as always. I suspect it might be one of my plugins but even with them all disabled it still continues to crash so I have no idea at this point. At the time of this log, two of them were disabled and the only one enabled was my Stream Deck plugin. For some reason the "Updates" tab in "Plugin Manager" can't even be selected so I have no idea about that. I'm sorry if this is a dumb question, I'm not very tech savvy so things like this don't come naturally to me. Any help would be greatly appreciated! If you need additional information, please let me know! :D
Thank you for your time!
If there are crash reports (you can find them in the main menu Help of OBS) then, please, attach at least one.
Unfortunately, there are no crash reports. However, anytime I open OBS it says "OBS Studio did not properly shut down". Then asks me if I want to run in Safe Mode or Normal Mode. :/
Not much info in the log above as there's no encoding session but I have some thoughts:
Your system is thin & it's low on RAM the moment OBS is opened. Close all apps not needed when using OBS. Clean-up your Scene Collection too, plenty of resources can be saved just by eliminating all of those duplicate captures. Heck start a new collection while you're troubleshooting, add just a single Source & test.
09:38:46.773: Physical Memory: 16297MB Total, 3805MB Free
Test with Avast out of the way.
Update encoding settings
09:38:48.097: Encoder ID 'jim_nvenc' is deprecated and may be removed in a future version.
09:38:49.943: Switched to scene '[Streaming] Gameplay'
09:38:49.944: ------------------------------------------------
09:38:49.944: Loaded scenes:
09:38:49.944: - scene '[Streaming] Gameplay':
09:38:49.944: - source: 'Shure Microphone' (wasapi_input_capture)
09:38:49.944: - filter: 'Gain' (gain_filter)
09:38:49.944: - filter: 'Noise Suppression' (noise_suppress_filter_v2)
09:38:49.944: - filter: 'Compressor' (compressor_filter)
09:38:49.944: - filter: 'Limiter' (limiter_filter)
09:38:49.944: - source: 'Stream Deck' (wasapi_input_capture)
09:38:49.944: - source: 'Radiant Dawn' (game_capture)
09:38:49.944: - source: 'Elgato HD60 S Capture Card' (dshow_input)
09:38:49.944: - monitoring: monitor and output
09:38:49.944: - source: 'Paint.net' (window_capture)
09:38:49.944: - source: 'Skribbl.io' (window_capture)
09:38:49.944: - source: 'DeSmuME Top Screen' (window_capture)
09:38:49.944: - source: 'DeSmuME Bottom Screen' (window_capture)
09:38:49.944: - source: 'Pool Code' (text_gdiplus_v3)
09:38:49.944: - source: 'Mist' (image_source)
09:38:49.944: - source: 'Powder' (image_source)
09:38:49.944: - source: 'Notification Alert' (browser_source)
09:38:49.944: - source: 'Current Event' (text_gdiplus_v3)
09:38:49.944: - source: 'Livesplit' (window_capture)
09:38:49.944: - source: 'Hide & Seek Wheel' (window_capture)
09:38:49.944: - source: 'Chat' (browser_source)
09:38:49.944: - source: 'Announcements' (image_source)
09:38:49.944: - scene '[Streaming] Thanks For Watching!!!':
09:38:49.944: - source: 'Audio Output Capture' (wasapi_output_capture)
09:38:49.944: - source: '2026 Thanks For Watching' (ffmpeg_source)
09:38:49.944: - scene '[Recording] Computer Screen':
09:38:49.944: - source: 'Desktop Monitor #1 Capture' (monitor_capture)
09:38:49.944: - source: 'Desktop Monitor #2 Capture' (monitor_capture)
09:38:49.962: [obs-browser: 'Chat'] Error: Uncaught Error: No provider for: InjectionToken(VISIBILITY_OBSERVER) (https://www.youtube.com/s/desktop/5af4fee3/jsbin/live_chat_polymer.vflset/live_chat_polymer.js:2192)
09:38:49.967: [obs-browser: 'Chat'] Error: Uncaught Error: No provider for: InjectionToken(SHEET_CONTROLLER_TOKEN) (https://www.youtube.com/s/desktop/5af4fee3/jsbin/live_chat_polymer.vflset/live_chat_polymer.js:1883)
09:38:49.988: [obs-browser: 'Chat'] Error: Uncaught EvalError: Refused to evaluate a string as JavaScript because this document requires 'Trusted Type' assignment. (https://www.google.com/js/th/HZFpKWaPPvR6C6_bAaRlw0j4zDJMf6y8Vtl3mtgTmLA.js:2)
11:16:27.587: ==== Shutting down ==================================================
11:16:27.646: WASAPI: Device 'Microphone (RODECaster Pro II Main Stereo)' Terminated
11:16:27.661: WASAPI: Device 'Microphone (RODECaster Pro II Chat)' Terminated
Hello!
Sorry for the late reply but I ended up cleaning up the scenes and deleting duplicate sources or sources that are no longer in use. It still doesn't close correctly, even with unnecessary programs closed. I had no idea about the RAM issue though, I guess it's time to upgrade to something a bit stronger! I really appreciate the feedback!
Your system is still viable assuming it's running with no issues. Your first log had basically no info after the Scenes loaded. Post the new log after you made the changes. It may contain additional info.
Sounds good! I will actually be live again here in a couple days so I'll just post a fresh log then! I really appreciate your help!
My advice, don't wait to go live to produce that log, it will be too late. Make changes & test prior. If you're still having trouble post the log.
That slight Rendering Lag is GPU overload & there's some additional encoding lag.
1. Finish cleaning-up the "Primary" Scene. It's still bugged with (1) Game & (3) Window captures.
2. Encoding settings - Change your Preset to P5 (Faster) & change Multi-pass from fullres to qres (this will decrease render times/faster). Makes changes on both encodings.
3) Recording only - Zero B Frames & disable Lookahead & Visual Tuning.
18:31:13.016: [obs-nvenc: 'advanced_video_stream'] settings:
18:31:13.016: codec: H264
18:31:13.016: rate_control: CBR
18:31:13.016: bitrate: 7000
18:31:13.016: keyint: 60
18:31:13.016: preset: p6
18:31:13.016: tuning: hq
18:31:13.016: multipass: fullres
18:31:13.016: profile: high
18:31:13.016: width: 1920
18:31:13.016: height: 1080
18:31:13.016: b-frames: 2
18:31:13.016: b-ref-mode: 0
18:31:13.016: lookahead: true (16 frames)
18:31:13.016: aq: true
18:31:13.016:
18:31:13.093: ---------------------------------
18:31:13.093: [FFmpeg aac encoder: 'adv_stream_audio'] bitrate: 320, channels: 2, channel_layout: stereo, track: 1
18:31:13.093:
18:31:13.154: [obs-nvenc: 'advanced_video_recording'] settings:
18:31:13.154: codec: H264
18:31:13.154: rate_control: CQP
18:31:13.154: cqp: 20
18:31:13.154: keyint: 60
18:31:13.154: preset: p6
18:31:13.154: tuning: hq
18:31:13.154: multipass: fullres
18:31:13.154: profile: high
18:31:13.154: width: 1920
18:31:13.154: height: 1080
18:31:13.154: b-frames: 2
18:31:13.154: b-ref-mode: 0
18:31:13.154: lookahead: true (16 frames)
18:31:13.154: aq: true
22:27:08.205: Output 'adv_file_output': stopping
22:27:08.205: Output 'adv_file_output': Total frames output: 849268
22:27:08.205: Output 'adv_file_output': Total drawn frames: 849200 (849294 attempted)
22:27:08.205: Output 'adv_file_output': Number of lagged frames due to rendering lag/stalls: 94 (0.0%)
22:27:08.208: ==== Recording Stop ================================================
22:27:08.346: warning: Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
22:27:08.433: warning: 2 frames left in the queue on closing
22:31:14.127: [rtmp stream: 'adv_stream'] User stopped the stream
22:31:14.127: [rtmp stream: 'adv_stream'] Socket send buffer is 2097152 bytes
22:31:14.127: Output 'adv_stream': stopping
22:31:14.128: Output 'adv_stream': Total frames output: 864019
22:31:14.128: Output 'adv_stream': Total drawn frames: 863966 (864062 attempted)
22:31:14.128: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 96 (0.0%)
22:31:14.129: Video stopped, number of skipped frames due to encoding lag: 150/864048 (0.0%)
22:31:14.134: ==== Streaming Stop ================================================
22:31:14.362: warning: 2 frames left in the queue on closing
22:48:58.716: ==== Shutting down ==================================================
22:48:58.740: WASAPI: Device 'Microphone (RODECaster Pro II Main Stereo)' Terminated
22:48:58.768: WASAPI: Device 'Microphone (RODECaster Pro II Chat)' Terminated
22:48:58.778: WASAPI: Device 'Desktop Microphone (RODECaster Pro II Secondary)' Terminated
18:31:13.016:
18:31:13.093:
Ok, just to make sure I have all of this understood correctly; the rendering lag and encoding lag are caused by the GPU being overloaded while OBS itself fails to close properly because my system is low on memory when its running? I just want to make sure I understand this. I really appreciate you taking the time with this, it means a lot to me!
Normally OBS closes without issues. Silently closes, silently starts. Plugins may change this behavior. You may run OBS without plugins - the program should start normally (silently) in the next run. When OBS asks you if you want to start it in the "Safe Mode" (no plugins) - click to yes, the safe mode. This choice is not saved. Safe mode active only per current session of OBS, and OBS will ask this question again and again after it detects unusual shut down (of itself).
Obviously, after normal run all plugins will be loaded and faulty plugin too, so the prompt to start "safe or normally" may appear only in the next run of OBS (after OBS closes in an unusual way because of the faulty plugin).
@rockbottom says that your system can perform slightly better if you configure it slightly differently. At least, it is my understanding.
Rendering Lag is GPU overload. Load reduction fixes this. Rendering Lag will cause Encoding Lag.
Encoding Lag is just encoding lag. Just need to use a faster Preset or other settings need adjustment like Multipass.
Example here:
Some rendering lag, not bad but there would have been 94-96 frames of encoding lag along with it but because you're using the wrong Preset & Multi-pass setting, you added some additional encoding lag as well.
I did mention it above but that Multi-pass setting also slows down your Render times. Qres is much quicker as that second scan is only quarter res. Anyway Fullres is too slow for Real Time Encoding. If you want to use it ----> Post.
Ok, yeah that all makes sense to me! I will play around with the settings you suggested as well as try out what @Suslik V suggested as far as starting in Safe Mode and see if I just have a broken Plugin somewhere. I wouldn't know how to diagnose which one is the problem but I can always respond later once I've messed around with it! Again, thank you all for taking the time, I really appreciate it! :D
I only see StreamDeck in your log. Certain versions of this plugin are known to cause trouble but I don't use it so no testing done on my end.
18:14:24.648: <StreamDeck> Plugin version 5.5.4.2
I would also disable HAGS, get it out of the way until you get it figured out.
18:14:23.231: Hardware-Accelerated GPU Scheduling enabled on adapter!
Even when opened in Safe Mode, OBS still fails to close properly.
This needs more details from your setup to understand the root of the problem. For example how you closing OBS. What programs (antiviruses, overlays etc) running simultaneously and step by step instructions how to reproduce the problem.
Meanwhile, you can try to run OBS portable mode in different folder. For OBS portable mode, please, read after the words "if it was not clear": https://obsproject.com/forum/threads/crash-with-«could-not-find-locale-ini-path»-when-opening-app-settings.82157/#post-346499 or in the Help section of the forum: https://obsproject.com/kb/portable-mode
Edit: for today you are looking for the file named "OBS-Studio-32.1.2-Windows-x64.zip", ~176MiB
