OBS and Droidcam - black screen cannot connect
Shmillinery
Hi everyone, I wanted to use my new samsung S23 ultra as my second camera. I download Droidcam obs app to pc and it installed in the right place. I also downloaded app to the phone. I put IP in, but cannot get anything but a black screen. All apps updated today
This is the log https://obsproject.com/logs/SHOL3DQPOEhG3tdN
Although I am nearly 70 years old, I thought I could work this problem out, but just not techy enough. Any help gratefully received
Many Thanks
Sara
Be sure to pair and activate the Droidcam source in OBS with the phone app.
Open the phone app; then click [Refresh Device List] in your DroidCam source in OBS. Select the phone in the drop-down and click [Activate].
More: https://www.dev47apps.com/obs/usage.html
thanks for the reply, but my phone doesn't appear in the device list?
Problems connecting a mobile phone using a wi-fi network.
Using an IP network, already on the same network as the cellphone I'm using, but the image doesn't appear. But if I use a cell phone network or mobile hotspot, it appears immediately. Can you help me. Thank you.
I've never used Droidcam, I have however used NDI without any problem. Download the app to your phone and install.
