OBS 29.1.2 MS HEVC installed, cannot select HEVC in output
deboopi
Hello,
I just installed the Microsoft HEVC codec on a Windows 11 x64 machine.
When I start media player I can view HEVC encoded files.
But when I open OBS , I still cannot select HEVC in output settings.
I included the log files.
How can I fix this?
Ok, but I have the same problem for recording, I attached a screenshot.
You have installed the 30.0.101.1338 driver version and the latest for your iGPU is 31.0.101.2115 as posted on the CPU intel page
Some times it's better to do a clean install:
And you should add at least one scene/source.
Hello,
I did a lean installation of the latest display driver.
I reinstalled the hevc codec.
I reinstalled OBS.
I could not see HEVC until I went to the advanced output settings.
At last, problem solved, thanks for the help.
