Question / Help Not sure why, but here's the log. (OBS Crashing, RAM 100%) Cont. Please help! [UPDATE]
Jason Bland
Member
Okay, So I have updated information about my stream, (I have a stream Log, and a link to that stream log's video on twitch.) First, I would like to direct your attention to the video located here(DELTED) (At about 2 Minutes 45 seconds, you'll see the error beginning, the choppy frames and pixelation. The beginning of the video is a reference to show my stream was working A okay without errors.) (I exited OBS before it crashed my computer, which at the time of the pixelation, was the exact time of my RAM beginning to skyrocket. I closed it when my RAM was at 94% and it rose from its constant 51%, at an exceptionally fast rate.) Last time I was told by one of the developers, Jim, that it was a decoding issue. ( Link to that post here, https://obsproject.com/forum/threads/not-sure-why-but-heres-the-log-obs-crashing-ram-100.28705/ ) His instructions were for a Roxio Game Cap HD though, and I am using an HD PVR 2. So, how do I fix this problem? I have also posted pictures of all my (important) HD PVR 2 settings, (Since the main program of the Hd PVR 2, *RC3*, Defines the encoding, Video output resolution, FPS, Audio and video signals to interpret, (Like RGB or HDMi, I change the settings in this program (*RC3*) because it will not work if I attempt to change it in OBS MP). and things of that various nature, basically this program defines the settings of the device.) Just curious, and thanks everyone, ~Jason
UPDATE: I was testing to mix and match my devices connected to my computer, to possibly see if they were running some interference. My devices are my HD PVR 2, my Logitech C920 Camera, and my Blue snowball USB microphone. I unplugged all except the HD PVR 2, it worked fine in streaming and recording, I plugged in my Camera, it worked fine in streaming and recording, Then I plugged in my microphone, and the RAM issue happened, I don't know what this means, but hopefully it helps decipher the problem. PS, I updated my drivers for the PVR 2 and The RC3 Program itself, it appears to have no effect.
  • 2015-05-29 20-12-02.txt
