Question / Help No game capture option
ooglebot8
Hello all! I wanted to stream a game but found that my version of OBS doesn't have it. Please let me know if there is a way to fix this!
Hey ooglebot! I'm having the same issues. I've heard that Mac users have to use Syphon Client, but OBS doesn't give me any options for the source.
Any help or advice from anyone would be appreciated!
Actually I found the answer to this! You have to go into your privacy settings and allow OBS access to your files.
Can you elaborate more on this, I'm experiencing the same problem and I want to retrace your steps
Hi guys!
Go to system preferences, then security and privacy. Go to the privacy subsection and scroll down on the list. Screen recording should be at the bottom, be sure to enable this. Your screen should look like this :-) Hope this helps!
OBS does not come up as an option on my screen.
