Multi-platform streaming and recording with the best quality possible
DominicCoca
Hi, I have this PC configuration and I am looking forward to advice on how to set up my OBS so I can get the best quality possible. At the same time, I want to stream on Twitch, Youtube, and TikTok simultaneously while also recording so I can post the video and edit it so I can make content for my YouTube channel.
PC CONFIGURATION: GPU Nvidia RTX 4080 Super, CPU Intel Core i9 14900kf,32GB ram 7600mhz CL36 XMP, Motherboard Aorus Elite X Wifi 7, SSD Samsung 990 PRO 4TB, AIO Arctic Liquid Freezer III 420, PC CASE Lian Li O11D EVO RGB
The Streaming I want to be 1080p 60 fps and the Recording 1440p 60fps.
Here is my Twitch channel so you can see the quality of my past streams https://www.twitch.tv/dominiccoca
Here is my YouTube channel so you can see the content that I'm currently making https://www.youtube.com/@dominiccoca5476
This video was recorded using NVENC AV1 bitrate 6mbps MKV https://youtu.be/z8UUIjhoAd8?si=UN4EGEx-CpX61sgu
This video was recorded using X264 bitrate 10mbps MKV https://youtu.be/DhLvYJHIjfU?si=8E-o6TRyPxrL2eYx
Also what recording format should I use I used to use MKV but the downside is that I can't use it to edit in Adobe Premier Pro, I'm currently testing out a hybrid mp4 format.
What settings and formats should I use to get the best quality possible?
