Question / Help MacOs Sierra OBS Failed to Connect to Server Issue
radroff
Failed to connect to server
The connection timed out. Make sure you've configured a valid streaming service and no firewall is blocking the connection.
I tried every setttings but still getting that issue I do not know how to fix it :S any idea ? I dont enable any firewall
07:29:06.189: Output 'simple_stream': 10 second delay active, preserve on disconnect is on
07:29:16.183: [rtmp stream: 'simple_stream'] Connecting to RTMP URL rtmp://live-fra05.twitch.tv/app...
07:30:33.711: The connection timed out. Try a different server, or check that the connection is not being blocked by a firewall or other security software (ETIMEDOUT).
07:30:33.711: Output 'simple_stream': stopping
07:30:33.711: Output 'simple_stream': Total frames output: 0
07:30:33.711: Output 'simple_stream': Total drawn frames: 4637 (4651 attempted)
07:30:33.711: Output 'simple_stream': Number of lagged frames due to rendering lag/stalls: 14 (0.3%)
07:30:33.712: [rtmp stream: 'simple_stream'] Connection to rtmp://live-fra05.twitch.tv/app failed: -2
Twitch has been having technical difficulties for the past week. Choose a different ingest server.
youtube also the same
19:04:41.341: The connection timed out. Try a different server, or check that the connection is not being blocked by a firewall or other security software (ETIMEDOUT).
