Free LioranBoard 2 Stream Deck/Animator [Deleted]
Status
Not open for further replies.
Hi, first of all, great work man. I want ask if lioranboard audio sounds only works when system is setup as output. Because i have goxlr mini and when i choose that i want use for example: Sample output for lioranboard in windows settings. It does nothing and still goes only from system output. So my question is if iam doing something wrong or for now lioranboard sounds are working only from system sounds and cant be changed to other output device. Thank you very much.
LB only works with the default audio output.
If you want to change the LB audio out, you need to change the default audio out before launching LB.
After you can change the default to something else and LB will stay on the new one until you restart LB
Thank you very much iSvein, it works! :) hope for future it can use other audio sources without this workaround because i add all audio sources separated in OBS to listen and control exactly what viewers listen over LB. Thank you very much again.
Any chance there's a way to make a box that can drag a source's position around on the screen? That would be very nifty.
Is there a way to get an OBS source object to automatically based on the cursor position?
I have a logo watermark I need to keep onscreen at all times, but if I zoom in, and get into the quadrant the watermark is currently in, I'd like to have the watermark move automatically to another pre-defined location.
For example, the cursor moves to the lower left quadrant, and the watermark is also in the lower left, the watermark would be moved to the upper right.
I saw that Andi Lippi has an effect that moves his webcam object when the cursor gets to it, and he said it is a Lioranboard thing.
Is there a way to insert a newline into a button text field, so the button can be multiple lines of text, instead of forcing the button to be really long? (also related to the corner radius thing -- sometimes the larger radius really doesn't work at all.)
Got this one.... the special character is "#" -- putting that after a character or word and it forces a new line. Thanks to one of Andi Lippi's videos for that one!
Is there a way to keep an old button from being used again?
I found that after creating a new button, having the ID value of "ID44", then deleting it, the same ID got reused again.... and the text value, and color, and border size was kept from the old button, and would not let me change it.
It seems that ID value is somehow persistent now... even after closing and restarting both the receiver and the deck.
(this is on a PC, btw)
I don't know if I'm the only one,but today I streamed and the board asked me to re-link to twitch. nothing unusual,periodic re-link,but when I opened the link the program just shuts down,I made it like 6 times in a row,then updated and kept happening.
didn't happen last week,just today: everytime I had to re-link and during that the program just shuts down,with last month update and this month's,so I guess it's not a program issue and something to do with online
Hi there,
I am trying to change the source of a VLC playlist... (actually just the directory from which OBS grabs the videos to play them). I can change image source and single video source, but not the directory source. Any tricks for that ?
Cheers,
M
Hey now,
I want to make a LioranBoard button that will trigger upon the redemption of a channel point redemption. I would like it to do a command in the chat that would be similar to !thanks [whoever redeemed that redemption]. I know that LB can put commands in the chat, but can it get the username of someone who redeems a channel point redemption?
Many thanks,
Slam
This happened to me recently. And then today I tried to launch it after restarting my PC and was getting the message about LioranBoard Receiver not being able to write to the folder. No big deal, I just got Kaspersky a few weeks back and figured I would just need to add an exception for LioranBoard as well as make it a Trusted App within Kaspersky. (LioranBoard ran fine until today with Kaspersky installed/running which makes this more puzzling.) However, even after adding it to both of those and even trying to move the install to a different location and permitting it again from the new location with Kaspersky, still getting the same error. Then I figured I would just close Kaspersky and all would be good but no dice. Still the same error message.
I also tried a fresh install of LioranBoard and deleting the GME.dll (I forget the exact name right now) as well as the configs from the lioranboard folder in AppData. Kind of at a loss at this point as to why it's still getting blocked. Hopeful it will get figured out because I've been using this for over a year and it's integration is crucial to the viewers experience in my stream.
If anyone has any ideas, I'm open to try any troubleshooting steps to get this working again.
Hello, how could i remove '№' from string? And maybe its more easy way to remove 'space' symbol from string, then copy it from unicode-table.com and paste into textbox(or how it named) and only after that it work correctly. Also is problem with '#', i copied one from twitch chat, and one from unicode, after that it work correctly.
For clarity, i'm talking about "String:replace".
Status
