High GPU & RAM Usage while running OBS and older Minecraft Versions.
Plumjet09
So I was trying to make a video where I play Minecraft 1.0 and tried to beat in in hardcore. I noticed that my recordings were at a very low frame rate so I increased the priority settings. Now all of a sudden Minecraft uses up to 8 GB of memory when I allocate it 1 GB and uses all of my GPU. This seems like a problem with an older version of Minecraft but It only used the allocated 1 GB before I changed my settings and was never intensive on my GPU. I have no idea what it could be other than OBS. Please help.
I think it might have messed with my drivers? Because AMD GPUs used to have this exact problem before the latest drivers were released, I’ll post logs in case that helps.
These problems persist with OBS being close or even uninstalled, I'm starting to doubt that this is a problem with OBS but if it is this is a MASSIVE issue for people who play older versions.
This is not a problem with OBS, uninstalled, and reinstalled drivers and problem persisted. I still have no idea what's causing it.
