Grouped sources keep moving every time I restart OBS
Mike Soultanian
I have two sources (browser source and color box) that are grouped and then I applied a location to the group transform. It looks great and then I restart OBS and it moves to the right and off the screen. I reset the horizontal placement, restart OBS, and it moves it to the right again. I can do this over and over and it will keep moving to the right after I reset it and restart OBS. What can I do to figure out what's going on?
Btw, am I supposed to be applying transform settings to the group, or to the sources within the group. Ideally I'd love to be able to do that because it's much easier than applying settings to individual sources.
Here's my log:
and it's the "Event list" group that is misbehaving.
Thanks!
Mike
You need to make the group set to upper left (0,0) and unbounded. Then you can move things within the group and they should stick. They should reference top left also, at 0,0.
I found a fix to this bug. So turns out if one of the sources is centered while the others are left aligned, the transform fails to update properly when it loads. The bug work around is make sure all the sources use the same alignment.
