Face Tracker
Face Tracker 0.9.1
Using this plugin makes the output image very dark. What am I doing wrong?
Probably I made something with wrong for a specific source type. Could you provide a little more detailed information including your device, color format, color space? If you don't mind, log file of obs-studio would be helpful.
This isn't my setup and I only use it once in a while.
Camera is Blackmagic Cinema Camera 6K going through a Blackmagic Design ATEM Television Studio Pro HD Live Production Switcher.
Color Format: NV12 (8-bit, 4:2:0, 2 planes)
Color Space: Rec. 709
Log file and source info attached.
  • 2023-09-24 08-11-43.txt
Hello,
Thank you for this plugin!
I'd like to know if it's possible to modify the Kp, Ki, Td (or other) values to obtain "instantaneous" tracking of the face. Can we eliminate smoothing, or easing, while keeping error (noise) deletion?
I've recently upgraded my ubuntu to 23.10. Now OBS won't start with obs-face-tracker installed. My output is the following:
debug: Found dbus service: org.freedesktop.ScreenSaver
debug: Attempted path: share/obs/obs-studio/locale/en-US.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale/en-US.ini
debug: Attempted path: share/obs/obs-studio/locale.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale.ini
debug: Attempted path: share/obs/obs-studio/themes/Yami.qss
debug: Attempted path: /usr/share/obs/obs-studio/themes/Yami.qss
info: Using EGL/X11
info: CPU Name: AMD Ryzen 3 3100 4-Core Processor
info: CPU Speed: 3886.469MHz
info: Physical Cores: 4, Logical Cores: 8
info: Physical Memory: 32009MB Total, 22958MB Free
info: Kernel Version: Linux 6.5.0-10-generic
info: Distribution: "Ubuntu" "23.10"
info: Desktop Environment: Budgie:GNOME (budgie-desktop)
info: Session Type: x11
info: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.21.1
info: Qt Version: 5.15.10 (runtime), 5.15.10 (compiled)
info: Portable mode: false
QMetaObject::connectSlotsByName: Connecting slot on_transitionDuration_valueChanged() with the first of the following compatible signals: ("valueChanged(int)", "valueChanged(QString)")
info: OBS 29.1.3.1-2 (linux)
info: ---------------------------------
info: audio settings reset:
    samples per sec: 48000
    speakers:        2
    max buffering:   960 milliseconds
    buffering type:  dynamically increasing
info: Initializing OpenGL...
info: Loading up OpenGL on adapter AMD AMD Radeon RX 6500 XT (navi24, LLVM 15.0.7, DRM 3.54, 6.5.0-10-generic)
info: OpenGL loaded successfully, version 4.6 (Core Profile) Mesa 23.2.1-1ubuntu3, shading language 4.60
info: video settings reset:
    base resolution:   1280x720
    output resolution: 1280x720
    downscale filter:  Bicubic
    fps:               30/1
    format:            NV12
    YUV mode:          Rec. 709/Partial
info: NV12 texture support not available
info: P010 texture support not available
info: Audio monitoring device:
warning: Failed to load 'en-US' text for module: 'decklink-captions.so'
warning: Failed to load 'en-US' text for module: 'decklink-output-ui.so'
info: Decklink API Compiled version 11.6
info: Decklink API Installed version 12.7.1
info: [pipewire] No captures available
info: [obs-face-tracker] registering face_tracker_filter_info (version 0.7.1)
info: [obs-face-tracker] ft_docks_init: Adding face tracker dock menu action=0x55bb0cdd8790
Segmentation fault (core dumped)
Hey there! Wondering if there's a way to reset the tracker to default (before it zooms in) when turning off the source in OBS). So basically it can zoom in any time I press it instead of staying zoomed in. Thanks!
Using multiple cameras (2 or 3) it would be nice if when I turn to look to the right that it switch scene to the camera on my right and when I turn left switch scene to the camera in the center or to my left. Basically, Turn Left scene 1 (camera 1), turn center scene 2 (camera 2) turn right scene 3 (camera 3). Is this doabe?
anyone else have a little issue where the tracking can shake violently? it doesnt happen often but im surprised it does....well lit room, expensive 4k camera, latest cpu and 4090 graphics card.....im as spec'd out as one can get
Hello @norihiro i have a question. norihiro is it possible, that the smooth zoom starts everytime when i switch to the Szene where my Facetracker is. So that it doesnt remember where the last zoom was and it has to zoom again every time when i switch on the Szene.
Sorry for my bad englisch. I hope you understood
This is covered in Advanced Scene Switcher.
norihiro updated Face Tracker with a new update entry:
Face Tracker 0.7.2
This is an experimental release.
Changes in 0.7.2
  • PTZ: Fixed a bug that the Zoom-out timeout was not disabled [#155]
  • Added options to hide filters and sources. Edit global.ini to hide each.
  • Updated dlib version to 19.24.4.
  • Add RPM files for Fedora.
Limitation
  • Not all binary packages are tested.
    • 0.7.2 is the latest tested package with OBS 30 on Intel macOS.
    • 0.6.2 was the...
Hi Norihiro , I enjoyed using this plugin in past OBS's but I can't seem to install it on my intel Mac. OBS 30.1.2. OS 13.6.7. Can you please tell how I might be able to fix it? Maybe I'm nor choosing the right installer for mac or something? Thanks.
Due to a bug I'm investigating, I removed the version 0.7.2 for Windows. The latest version for Windows user is 0.7.1.
The bug causes OBS to crash once a face is detected by the plugin.
I'm sorry for the inconvenience.
Hi Norihiro! I don't know if anyone has the same problem as me, but I have a couple of docks called “FTDock” and FTDock-1” that are linked to the Face Tracker plugin that I can't remove from my dock list on OBS. I wanted to know if you had a solution for me.
I know I created them by clicking on “New Face Dock...” in the OBS tools menu. But I can't find the option to remove them from the list of available docks in the OBS menu.
Thanks for your help!
