Capture cs2 with anti-cheat
SIBUN
When running cs2 with anti-cheat obs does not capture the game. Without anti-cheat obs sees cs. what to do?
That's correct. You can't use game capture method because Valve blocked it.
Valve has implemented a Trusted mode which does not allow OBS to hook CS:GO using Game Capture. Read more in their announcement post. Additionally, they have no plans on allowing OBS in Trusted mode.
You will need to run the game in either windowed or borderless fullscreen and use Window Capture instead. Alternately, you can launch the game with -allow_third_party_software .
I use this -allow_third_party_software. I have fullscreen. Literally the day before yesterday everything was working fine, the stream was working, cs was shown, but then at the moment cs2 is not shown in obs, without anticheat cs in obs works, with faceit anticheat already no.
That tells you that faceit anticheat needs to be updated too to work with the latest OBS version.
Just install the previous version where it do work until they update the anticheat. Contact them for more info about it.
