Question / Help BSOD while streaming only (NT Kernel & System)
SwiFii
I’ve a BSOD everytime I stream, this is never happen when I’m not.
The problem seems to be “Kernel” I don’t really understand what is it and I don’t know how to solve it.
So there is the crash report
: crash dump file: C:\Windows\Minidump\050220-23062-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1C2390)
Bugcheck code: 0x154 (0xFFFFDB08676DE000, 0xFFFF9E8E36BF16E0, 0x1, 0x0)
Error: UNEXPECTED_STORE_EXCEPTION
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that the store component caught an unexpected exception.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
I tried to change my RAM memory but it does the same.
I hope you can help me because I don’t know what to do and it’s been a month since the first Kernel BSOD shows.
Thanks for reading and your help !
I precise that I've done a lot of things to fix this and i'm working on it since a month...
"a lot of things" like update drivers, uninstall the GPU's driver and install it again, repair disks and format Windows 10.
I don't know anymore how to try to fix it, I need help :(
