Question / Help Best OBS Settings for me Setup
Dojon
Hey guys!
Since 3 Weeks im streaming on Twitch and its alot of fun for me! The only problem I have is the quality of my stream. I think my PC is not strong enough to handle OBS + Game :/
The quality is very low and doesnt look good on Twitch. Most time there is a huge delay of my speaking and my face/webcam, what looks horrible.
Maybe one of you can help me <3
My Computer-Setup is:
GPU - GTX 970 4GB
CPU - AM3+ (FX-Serie) - AMD FX-8320 8x 3.5 GHz (overclocked to 4.1 GHz)
RAM - 16384MB DDR3 Dual Channel 1333MHz (2x 8GB)
Mainboard - Gigabyte GA-970A-UD3 (Chipsatz:AMD 970/SB950/ATX)
Additionally I upload a screenshot of my settings in OBS for you
(Edit: I can't upload any screenshots atm so I will type it here for you)
In OBS Settings -> Outout ->
Encoder: x264
Enforce streaming service encoder settings (is marked)
Rescale Output (not marked) 1920x1080
Rate Control: CBR
Bitrate: 2500
Use Custom Buffer Size (not marked)
Keyframe Interval (seconds, 0=auto)= 0
CPU Usage Preset (higher =less CPU) = veryfast
None
None
Variable Framerate (VFR) (not marked)
None
OBS Settings -> Video ->
Base (Canvas) Resulotion = 1920x1080
Output (Scaled) Resulotion = 1280x720
Downscale Filter = Bocubic (Sharpened scaling, 16 samples)
Common FPS Values = 30
OBS Settings -> Advanced ->
Process Priority = High
Video Renderer Direct 3D 11
Color Format NV12
YUY Color Space 601 YUY Color Range Partial
I hope there are all information you need to give me some tips what I can do to push the quality of my stream.
I would be more than happy if someone knows how to help me! You guys are best!!!
Dojon
