Background Removal / Virtual Green-screen & Low-Light Enhance
Background Removal / Virtual Green-screen & Low-Light Enhance v1.3.7
royshilkrot updated Background Removal / Virtual Green-screen & Low-Light Enhance with a new update entry:
v1.3.3
Release 1.3.3​
We’re excited to announce the release of v1.3.3! This update brings significant improvements and expanded support, especially for Windows GPU users and ONNX Runtime providers. Here’s what’s new and improved since 1.3.2:
Major Improvements​
Windows GPU Support Returns!​
  • Windows GPU builds are back: Now you can easily build and use the GPU version on Windows. Build artifacts are named more clearly...
v1.3.4
Hello everyone! We're excited to bring you version 1.3.4 of obs-backgroundremoval. This release focuses on important bug fixes and smoothing out the experience across platforms.
️ What's Fixed?​
  • CUDA Option on Linux:
    We fixed an issue where the CUDA option wasn't showing up for some Linux users. This turned out to be a small typo in a preprocessor macro—now it's corrected, and the CUDA option should appear as expected!
  • macOS Installer Link:...
Hello guys. I'm actually using the Nvidia background removal tool on Obs , but im thinking to go with amd with the next gpu. Anyone can tell me if this plugin Is near the quality of Nvidia broadcast considering also the cpu/GPU usage? Thanks a lot
v1.3.5 — Stability-Focused Release
Hello creators and streamers!
We’re excited to announce version 1.3.5 of OBS Background Removal—a release dedicated to improving the reliability and smooth operation of your favorite background removal plugin.
️ What’s Improved?​
  • Race Condition Fixes:
    We tracked down and resolved several race conditions in the plugin’s core (including enhance-filter models and stage surface data handling). This means fewer unexpected behaviors and more robust...
Hi! I've been having some issues with the install/setup of the background removal plugin. I extract the zip file I downloaded, then copy the "obs-plugins" and "data" folders and paste them directly into the "obs-studio" folder in program files. This is the usual procedure I follow when downloading resources that don't come with an installer, but everytime I reopen OBS after installing this particular plugin it says that the plugin could not be loaded with an error popup.
Is there anything I am doing wrong? advice would be much appreciated :)
Please report an issue on GitHub with clash report and logs https://github.com/royshil/obs-backgroundremoval/issues
Tried to follow the install instructions and it's not showing up in OBS at all.
Can you give us some more info? Windows, Mac etc... Are you selecting the correct installer for your machine? Is your OBS up to date? Is your computer up to date? Are you looking in filters for it? I'm not an expert, but would like to help if I can.
Congratulations on this excellent tool. However, I would like to point out that on my notebook, the background image does not appear when I use OBS-background-removal. The background is removed correctly, but the background image does not appear. I believe there is a rendering problem, perhaps an incompatibility with the graphics card. My notebook is a DELL (Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz 2.20 GHz), Graphics card (Intel(R) HD Graphics 5500 (128 MB)). Is it possible to fix this? I am already using the latest version of OBS and OBS-Background-removal. Thank you.
מישהו יכול להסביר לי איך אני מתקין את התוסף הזה בפשוט מה צריך להוריד איך אני מגיע לתוצאה שאני פותח את המסננים בתוכנה ואני מסיר את הרקע אין לי מושג בזה בכלל
We have GitHub Issues to help you develop for your environment. https://github.com/royshil/obs-backgroundremoval/issues
macOS26, v1.3.7, OBS v32.1.2
no matter which segmentation model there is an ugly mid transparency outline around all of my body. If this can be fixed I would be very happy and can use this plugin. Until than it is not possible to duplicate the cam and put objects between me and my background.
Describe the solution you'd like​
No visible outline (only occurs while doubling the cam - one without and one with plugin) when plugin is active.
I swapped my face for privacy reasons.
Technical Justification / Feasibility​
Without the fixing you can not use this plugin for my purpose.
@umireon Calm down. On github I cannot announce a bug because there is no LOGfile for the problem, no crash, no nothing. But those Logfiles and crashreports are mandatory. So I cannot send a bugreport. So I assume you got a bug in your bug reports.
Secondly your "nice" hint that you are not my paid technical support is ridiculous. I know that but bug reports are for bugs. So I volunteer in reporting bugs and you volunteer in whatever you want to. So please calm down or change your hobby if you are instantly attacking people over on Github.
