Working Fine are you on windows or mac?
On windows , let say you have the files in a folder called c:\obs\lower3rds ( you will need to adjust for your case)
in the custom docks you need: file:///C:/obs/lower3rds/control-panel.html
in the browser source you need: 1. uncheck local file 2. file:///C://obs/lower3rds/browser-source.html
Hi there, on OBS 29.0.1, the Logo image doesn't load.
I tried everything, without success.
is there a fix ?
edit: let me rephrase that. The Logo load in the image load process but in the preview, it show "broken image logo" and when lower third appear, we also got the Microsoft broken image logo 16x16
yes, this work, but it is not required. On Obs 29, don't click local file, and just paste a regular path without the file:// and all the %20 and it work. (at least on PC)
The image doesn't show and is only showing the broken image icon. What should I do to correct it? I have tried many different image to rule out that it wasn't just the image I want that was the problem. There's an issue with the lower thirds itself as as soon as I press ok, it becomes broken. I changed nothing in the html code. Log file is attached below if its needed.
I am having the same missing icon or broken icon image issue. The logos I got with my kick-start package from AJtheCEO work, but the PNG icons I put in the same directory do not. All settings appear to match. I see several people are struggling with this. Are there logs or events I can check to determine why I keep getting the broken icon image?
I realize that there hasn't been an update to this plugin for 2 years now, but I'd like to put this out there in case there is interest from anyone else.
I have some scenes that display input from 2 cameras side-by-side. I would like to have 2 separate lower third areas overlaid over each of the two camera sources but be able to independently display a lower third on each of them, perhaps by linking all presets from "Lower Third 1" to one camera feed and "Lower Third 2" to the other area so that when I click a memory slot in "Lower Third 1" that lower third only displays on the left camera feed and if I click a memory slot in "Lower Third 2" it will only show on the right camera feed.
Currently if more than one Lower Third source is added to a scene the lower third will duplicate on all sources in the scene.
Another way to say what I am thinking is that I would like to be able to selectively link the 4 specific lower third groups to individual/multiple lower third sources in a single scene.
Does anyone have the issue, if you change the style option of the lower third, the logo option disappears completely and doesn't return, without resetting the config. I can replicate the issue every time, even with no config in there, i change the style and poof, logos disappear. Thoughts?
Hi, is the memory slots supposed to be erased after closing the application? Every time I close the application and reopen it, all memory slots are cleared. I tried backing up and importing that backup, but the backup apparently only records what is in the queue at that point in time. Do I need to switch to each memory slot and back them up individually but also would it be able to read multiple backups and place them in the correct memory slot etc?
From my little experimentation, you can use each lower third as independent. However, the max you can display on one monitor at any one time is 3 LT and the only style that allows this is style 2. Select is and just change the alignment to be left on one LT and the right alignment to be on LT 2. Make sure both of them are on and it should work.
First of all, I tried to look into the html, css and javascript code to find the problem with the logo.
I found a few pointer in the right direction, but not a "perfect" solution
The logo directory seem to be hard coded into the application, so if you load another logo, you'll see it in preview, but the code will replace the location of the file and switch it back to the logo directory (it will keep the name of the proper file though but search for it into the wrong directory)
so, the first solution for this issue is to put your logo file inside the logo directory of the application.
Second issue, when you switch from let's say config 1 to config 2, when you come back to config 1, your logo is replaced by a broken image.
I found the solution for this as well but not why the code is acting like that.
The solution (not a perfect one) is to place a file named "logo.png" inside the logo directory with the proper image.
it seem that when you switch setting, the location and file name of the file is replaced with the logo directory and the file name is replaced with
so... here you can see it in action into this video:
Regards from Spain.
I'm experimented crashing of OBS once you selected the logo, to introduce another custom one!!!!. Seams to be incompatible with OBS 29.XX, for linux Ubuntu latest realse.
Let me know if will be any kind of upgrade for newest releases of OBS.
Thx a lot for your work, Ignacio
is their a way to run this on a web server. I am able to access the control-panel.html on a remote machine, but I am not able to control the browser-source.html from a remote machine
Hello everybody! I recently installed version 1.6 and it's working perfectly. However, I would like to know how to automate the rotation of the lowers (I'm using 3, Twitter, Instagram and TikTok). I'm breaking my head and I can't get this to work...LoL
Thank you for all your help and sorry for my English.
Hey I really like the plugin
but I don't know if there's a settings or need to edit the source code (CSS) for another type of transition / animation like FADE because all 3 style have the same fix transition / animation -
SLIDE or SWIPE
Great tool, thank you very much, NoeAL!
It runs perfectly when I use it with the control deck.
Next level would be to control it with my Stream Deck. But the Hotkeys are not working !
I fumbled around quite a while now but couldn't get rid of this error:
[lower-thirds_hotkeys.lua] Failed to call hotkey_pressed for hotkey_pressed: ...ugins/Lower-Thirds/lower thirds/lower-thirds_hotkeys.lua:436: C:/Program Files/obs-studio/data/obs-plugins/Lower-Thirds/common/js/hotkeys.js: Permission denied
I thought it is a admin thing, but also moving the file to a public folder doesn't work.
Did someone experience sth similar? Any idea?
Thanks in advance!
Mr. Proxy
This plugin is so amazing that I feel guilty for even commenting with my pitiful issue!!
I can't cut, copy or paste in the variable fields in the form on the control dock. It would be nice to have that ability for names, hex color codes etc.
The problem remains in 29.1.1 for me. Red box on lower thirds even if the Main Settings box is blue. Is something changed in the steps for troubleshooting?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
