Free Animated lower thirds with control panel 2020-04-12
I'm confused. What's the purpose of the memory slots? How do you add a lower third to the memory slots? They've got me really confused as to their purpose and how to make them.
Hi, there's another tool based on this one. I think you're looking for help with this another. Link: https://obsproject.com/forum/resources/animated-lower-thirds-with-dockable-control-panel.1057/
I leave you an answer where I explain how the memory slots work:
Hope it helps you.
from1975 submitted a new resource:
Animated lower thirds with control panel - Lower thirds on the fly. Completely free!
Hey, I'm presently having an issue with the software. I unintentionally dropped a secondary OBS docker on top of lower thirds (I was trying to place it next to it) and it crashed lower thirds entirely and OBS has been buggy ever since.
Errors since this happened:
- OBS no longer displays the icon for OBS, even after complete uninstall reinstall
- OBS cannot find the lower thirds docker (I title it lower thirds in the add url page, click on the lower thirds.html file to get the url, and add it to the system), but the docker's control window populates.
- I have removed and added the hotkey .lua file to the scripts
I have essentially done everything I can think of to get the program working as intended again and went so far as to remove everything, even my profiles, and start from scratch with OBS and nothing is fixing this issue. I need some help.
Thank you.
What's up homies? I'm getting notification at my channel about how all boxes stay highlighted in red even though the Main Settings are
Turned on. I reinstalled OBS fresh and installed this tool and low and behold the problem occurs on my machine as well. Anybody have this issue? Andy ideas on a solution? If you found one I will absolutely make a video about it. Damn maybe the tool is having problems with version 26.0??
Hi, I was wondering if there was any short cut keys to be able to control the (start/stop) the 4 lower thirds panels? Or, is there a way to be able to control this feature with Touch Portal?
It's been a while I've been on the forum. Well, actually months.
I hope to catch up on updates, as well as pick up from where I stopped.
I really like this plugin. I would make a suggestion to allow this to grab text from a file, so you can marry it with other plugins that dynamically show newest followers and subs. I like a minimalistic look, but to have a lower thirds that pops up in a sequence to show this information would be fantastic
This Plugin is really great because it is kept very simple but also adjustable.
I have just one question: Does anybody know if there is a possibility to use this plugin with shortcuts for showing and hiding? That would be really great!
I have an issue regarding Docking Lower Thirds, nothing seems to appear after following all instructions. refer image... Need Help
What exactly did you dock? browser-source OR control-panel?
You should be docking the control-panel.html, then add the browser-source,html as a Browser Source in OBS
You can register the lower-thirds_hotkeys.Lua file in OBS Script window to add Hotkeys functionality.
thank you.i have a problem with this plugin.how fixed it?
Looks like it does not read CSS files linked to the controller, probably after copy-pasting files between different location. Make sure all plugin's files on your PC remain the same structure as in the .zip.
