Adding a Second Monitor Freezes/Crashes OBS HELP!
Okami22
I have been streaming with OBS for months and everything has been more or less fine. A few days ago I got another monitor so I could read chat but everytime I open OBS with my monitor for gameplay and monitor for chat obs will freeze and eventually crash. Whats weird is if I have OBS open THEN add the additional monitor its fine until I close and re-open OBS.
im on a legion pro 7i 4080 and I have tried a lot to fix the issue so I dont have to unplug the hdmi at the end of a stream then plug it in right before the next one. I changed everything to the same Hz and nothing, added a specific registry file, nothing. Started up in admin mode, nothing.
Looking for any solution on this, thanks in advanced!
Added a monitor & if your pushing high refresh rates, especially on both, your CPU may be tapping out. Change both monitors to 60HZ & try again. Sounds like you're running out of resources. OBS shits the bed & no crash log.
Switched all 3 to 60hz and it still crashes OBS, its weird because if i plug in the hdmi AFTER obs is open all everything works fine. its only if i have everything plugged in prior to opening OBS
